メインコンテンツにスキップ
This HD video recorder contains an excellent camera mode that records and detachable stereo microphone capsules.
7回答 すべてを表示
Why does my Q8 Camcoder suddenly turn off during my recording?
My Q8 Camcoder sometimes turn off when I was recording. I checked the battery and SD card spaces they all look perfectly fine. It is not a problem caused by battery and storage space. I could not find the reason why the camera suddenly blackout during my recording process which makes me very frustrated, and I cannot make a complete recording since I can not predict when it’s going to be dead.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
I try recoding my band and the camera shuts off after (Approximately) 45 minutes. I can't even film a whole set. Very disappointed in this camera. Would not recommend anyone to buy this camera at this point.
さんによる
コメントを追加
1 件の回答
This is due to a limitation of the .mov file, which the Q8 and Q4 use to record. The maximum size a .mov file can be is 4GB. Once this limit is reached while recording with the Zoom camcorder, it will begin a new file to continue further recording , if this does not happen check in the settings to see if you can continue recording after it has reached the 4gb file size.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What settings? There is nothing in the settings menu to adjust this that I can see.
さんによる
コメントを追加
回答を追加する
Dailin Zeng さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 345
