メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
88回答 すべてを表示
Help needed removing stripped screw.
First of all, i would like to start off with a ‘mini’ description of my product. I own a iPod Mini 2nd Gen 4GB (with the original drive). Now to my problem.
The problem is obvious, i stripped the screw nearest to the hold switch, and would like to get a non-destructive (to the iPod, headphone out board, and housing) method of extracting the screws out of my iPod mini 2nd gen. All ideas are welcome (besides drilling it out).
Thanks for any future answers!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Use a rubber band between the screw and screwdriver bit. Most of the time it will give you enough grip to pull out the screw or at the very least get it loosened. Use a screwdriver bit one size up from the actual head of the screw when using this technique. Don’t be shy in applying force on the screw while you slowly turn to the left.
How does this work you may ask? The rubber band fills in the backs of the screw head. So don't use a super thick rubber band but don’t use one that’s almost invisible either.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
the bongo guy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 277
