メインコンテンツにスキップ
LenovoによるChromebooksの修理ガイドならびにサポート情報。
111回答 すべてを表示
Why is my chromebook not working #2?
Before my chromebook stopped working, It would sometimes just randomly go on a black screen and if you tapped it gently it would go out but then one day it just went on the black screen and you couldn’t use it. No matter what you can’t see anything on the screen, it’s just pure black and we can still see a bit of light coming out of it but everything is black and you can’t do anything on it. Also when we charge the chromebook, the battery color is red. I hope someone can help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
ok so what happened is you are having a backlight issue with the lcd, your backlight has gone out so you will need to get the screen replaced. but before you go to that have you damaged it at all?
このアンサーは役に立ちましたか?
スコア 0
9 件のコメント:
The screen is broken a bit.
さんによる
so yeah your backlight got damaged and thats why its not working
you will have to get your screen replaced
さんによる
how much would it be to fix it?
さんによる
depends, on the year, if its touch screen, and model, and as well how much the repair shop would charge you
さんによる
if its touchscreen it will be more expensive
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Turbo Cap さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 91
