メインコンテンツにスキップ
The Canon Rebel T6i is a popular, semi-professional grade Camera with a 24.2 MP sensor designed for any user. Also known as the EOS 750D and the EOS Kiss X8i, this guide is meant to aid in the repair of a few common problems that may occur during normal use.
20回答 すべてを表示
My DSLR doesn't recognize my Flash
My Canon 750D / T6i doesnt recognize my external flash
I use Godox TT685C it worked on my Friend’s DSLR
I think The Problem is the Hot Shoe Maybe
*The little piece of metal that hides the Screws is missed.. but it doesn’t affect*
i tried Godox V1 and TT860 but also didn’t work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would start by cleaning the contacts with whatever alcohol you can find.
Update (10/04/2020)
Try:
- Update camera firmware
- Reset all settings (maybe some setting is making your flash not work)
If that doesn't help you will have to open your camera to take a look at the connections/wires, for what I see in the picture it has a lot of moisture/dirt that may have creeped inside.
https://youtu.be/hpnWB3Yzcac
Here is a disassembly guide
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Still doesnt work
さんによる
Can Someone help me fixing this problem please ?
さんによる
コメントを追加
回答を追加する
Ahmed Mohamed さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 627
