メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
I cannot hear the person Im calling?
I have replaced my rear panel and front assembly, everything is perfect but when I make a call I cannot hear the other person. If I press speaker then I can hear.
I took apart iPhone and made sure connector 1, 2 and 3 were seated correctly as this are the only thing I can think of.
Done this 3 times with no success....
Ok, it is connector 3 thats the problem, I have inserted it in several times but no joy. Is it possible that the from assembly I got on ebay is faulty or is the connector on my logic board faulty.
So Ive figured out the digitiser has nothing to do with it as connector 3 is not even part of it. Its the middle frame assembly that has connector 3. So can someone please tell me how to remove the earpiece and connector 3 on the frame.
That sounds fine but now Im thinking it could be the connector 3, the fps connector. How can I tell if it needs replaced as this is the connector for the earpiece and proximity sensor and this is also not working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You can change the whole midframe. Its alot easier to do compared to changing just the earpiece. Ive tried to change just the earpiece and havent been successfull. I would suggest buying a midframe from eBay or something and heating the digitizer off the midframe then gluing onto the new midframe.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 784
