メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Why do I get occasional colored lines across half the screen?
I thought at first that my hard drive had crashed because I tried to start up the machine and it made it to the apple on the screen, but then no further. I tried restarting a couple of times and it was no go. Then I tried again after a couple of weeks and it booted up just fine. I have even upgraded to Leopard since then and it's doing fine. But every once in a while, I get what looks like a bunch of colored lines that completely obscure part of the display - usually the lower half of the screen. If I wiggle the screen, I can make it go away. Perhaps this is unconnected to the earlier failure to boot, I don't know. I have a suspicion that the cable that connects the laptop's display is malfunctioning, but I thought I would ask the experts and seek the recommended repair.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
This recently happened to one of our own PowerBooks, four months after we sold it to a friend. She ended up having to get it repaired. It's a known issue; I found lots of similar reports in the Apple forums. It started out as just a band of black obscuring the bottom of the screen, then progressively ate up more of the screen as weeks went by.
さんによる
コメントを追加
1 件の回答
選択されたソリューション
Since wiggling the display can affect the issue, it is possible the video cable is damaged. The cable runs thru the clutches in such a way as it can be pinched or wear thru the insulation.
The video cable is the blue and yellow cable running thru the right hinge in the following picture:
http://s2.guide-images.ifixit.com/igi/io...
This is a tough repair, as replacing the cable will require a complete teardown of the entire notebook and display assembly.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
christinekling さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,112
