Screen turned translucent white out of nowhere
The screen turns whiter the more you move it around and when you turn it off and on it restart until It becomes almost completely white
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Looks like it’s an issue with the display and it will need replacement I see this happen quite often with these phones. If it was repaired before I would see if whoever repaired it offered any kind of warranty with it. If it wasn’t repaired, you can order a kit here on ifixit. I would recommend sticking with an OLED panel rather than going the cheap route with an LCD. Due to the LCD’s higher energy consumption, you run the risk of damaging the display connector on the board or it may impact battery life.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
