メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
20回答 すべてを表示
締切られた回答
Boot loading bar gets halfway and hangs
My computer has been in a closet for over a year and I tried to start it to clean it up for my grandchild.
When I turn it on, I hear a “gong” then the Apple logo appears and once the loading bar gets halfway, it just hangs and gets stuck. It was just staying illuminated like that.
I tried to start it in a safe mode by pressing SHIFT and restarting. The result was similar but now it goes dark after it gets about 1/3 of boot.
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Did you plug in the MagSafe charger in? What is the color of the connector Amber or Green? If Amber let it be! Check it in eight hours is it still Amber?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
LOL I think you need a coffee Dan.....
さんによる
@livfe - Your a bit late! This is an old question, note the date!
Besides, this is a proper diagnostic process for testing the basics.
さんによる
@danj Agree but then it coould have been stated in your answer to be more clear, there are loads of unanswered questions that need answers to help anyone out if they have the same or similar problems.
さんによる
@livfe - How would you state it? Re-write the Answer that would meet your concerns.
さんによる
コメントを追加
Sounds like a very similar issue I had. Connect up the charger and try running apple diagnostics (Power up and hold 'D') follow the prompts to see what comes up in the results and post it for us to see.
Error Cannot Load EFI Drivers
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
@livfe - As I explained Apple broke Diagnostics, which is why you get this error. This has no bearing here.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 67
