メインコンテンツにスキップ
The digital camera was released by Panasonic in July of 2016. The Panasonic Lumix DMC-ZS60 has 18-megapixels and wifi mobile device connectivity.
2回答 すべてを表示
Popping/Cracking Noise when zooming
When the camera is powered on, the lens makes a small cracking noise while extending. Other than that it works normally. How can I fix this?
Thank You!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Andrew Jensen  sounds like you may have some dirt/debris in there. Other than disassembling the lens and trying to clean it, which is a challenge without proper manual, there really is not anything you can do to fix it. Only other thing is to replace the lens Panasonic Lumix DMC-ZS60 Camera Lens Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Jensen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 413
