メインコンテンツにスキップ
Broken USB mouse receiver, plastic came off
Hi IFixit community,
The USB receiver for my keyboard and mouse had the plastic piece come off of the receiver. I've attached some images for reference as it's difficult to explain. How can I fix this? will glue work, or will that damage the receiver?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
HI
Do you have the model no of the mouse?
iFixitでの質問に画像を追加する方法.
さんによる
Hello Matthew, for some reason I can't see the pictures you attached, but if you can give a bit more information I can try to help!
さんによる
@maker600 oops! I'll try adding them
さんによる
@salmonjapan I'm not sure, do you mean the number of my specific mouse and keyboard or the model itself?
さんによる
Haha it happens, but i will take a look once you do. Hopefully i can try to help. :)
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
選択されたソリューション
Hi Matthew, so I am no expert, but judging from the pictures you sent it does not seem like the receiver was damaged and could still be funtional. My suggestion would be to gently wigle the reciver left and right while pulling it out of the laptop. Then look and see what the correct orintion is for the black casing of the reciver would be. After that apply a small amount of super glue to the inside of the casing (not so small that it does not stick, but also not so much that super glue will ooze out of the casing). Lastly, put the casing back on the reciver in its correct orintion. I hope your mouse works and best of luck to you!
I say use superglue since for me it is easier to control how much glue I want to use, and I find that it works well in terms of strength for plastic.
このアンサーは役に立ちましたか?
スコア 0
コメント:
thanks so much!
さんによる
@Matthew Chambers, I hope it works, fingers crossed haha!
さんによる
コメントを追加
回答を追加する
Matthew Chambers さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 138
