メインコンテンツにスキップ
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
23回答 すべてを表示
Wont charge past 2% tred differet cords
My phone will not charge past 2% is there any guids that can help me fix it? I had it for 2 years dont want to pay $80 to take it to the shop
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@chefnoyes start off with a new battery. After that you will need to check the charging port. If that is okay you will need to check the components on the circuit board. One suspect would be a bad power management IC but there are plenty more suspects. I would replace the charging port flex since that would eliminate most other suspects. You can get a replacement at places like this Once you replaced the battery and find you have to disassemble your phone post plenty of pictures with your QUESTION so we can see what you see. This video will at least get you into the phone.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
joe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 200
