メインコンテンツにスキップ
A digital TV converter box by Apex Digital.
Power Light won't stay on
Apex DT502 digital converter box is hooked up. But when I press the “ON” button — either from the remote or on the box itself — the light turns from red to green, then immediately back to red. It won’t stay green at all. If I press and hold the power button on the box, it just flashes red. Any solutions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
It seems as though it is either going into some sort of protect mode or perhaps there is a problem with the power supply in the box.
I cannot find a service manual or schematic for the box online so you may just have to open the box and initially check the power board for any obvious component damage such as heat stressed components, bulging or blown capacitors and dry solder joints on the back of the board.
Here’s the ifixit Apex Digital DTV Converter Box Power supply Board replacement guide that may or may not be of some help. I don’t think that it is the same model as yours (possibly a DT-250A?) but hopefully it is similar enough to be of some help.
If you see something wrong and/or you’re not quite sure, post some close up images back here. Here’s how to do this iFixitでの質問に画像を追加する方法
Apex Digital DTV Converter Box Power Boardの画像
ガイド
難易度:
簡単
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
farmerzdtr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 622
