How do you replace the battery in a Harman Kardon Onyx Studio 4
How do you replace the battery in a Harman Kardon Onyx Studio 4 speaker?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I would be sure that your charger is actually charging properly first.
to gain access, slowly work front cover off all around using your thumb nails.
After cover is off, you will see screws to get in.
このアンサーは役に立ちましたか?
How can you Know that the speaker properly charging? I mean the whiteb light is blinking like normal until until the speaker is supposedly charged an hour or two later and then the speaker works fine it's just not lasting as long as it used to. So should I replace the battery?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 20
今までの合計 2,264
6 件のコメント
Thank you! I will try another power cord I was able to take off the cover and find 5 plastic hex key screws Do you know what kind of battery is inside?
Darren Muci さんによる
This should be the battery you need.
Search this ebay:
Battery for Harman/Kardon Onyx studio 4 Replacement Harman/Kardon ICR22650 New
Rodney Miller さんによる
Also you might try a different wall socket for your charger.
Rodney Miller さんによる
Thank you very much, Mr. Miller; I appreciate your time and very helpful responses!
Darren Muci さんによる
@darrenmuci You Sir, are very welcome.
Rodney Miller さんによる
1以上のコメントを表示
