メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
iPhone 7 randomly turns off
Hi I recently bought an cracked iPhone 7, in hopes of resseling it, note it was my first time fixing an iPhone, I bought the replacement screen, and put the bluetooth home button, the first time i encountered the problem was when I finished it all, it started turning off and then on until it drains a battery which happens really fast, it usually happens on 20% and 50%, I tought it was due to battery which was replacement one even though it was on 100% health, so i replaced it with the original one, and when it is about to turn off it becomes very hot under the rear camera, I cleaned all the connectors with PCB cleaner with awarenes of not damaging it, I also have to menition the backplate on battery and the lcd connectors has only one screw holding the backplate, also the display backplate had one bruised screw which I had to cut off and bruise that backplate side, but the display is fine.
Any help would be appreciated, thanks in advance!
Update (09/12/2020)
It was due to battery, I replaced the replacement battery with the original one, after that it shut down just once and it drained my battery from 52% to total 0, after that It didnt shut off, I can also use various apps it wont turn off, thanks everyone!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Wasn’t the bluetooth homebuttons the first working ones out on the market for iphone7/8? I dont know how reliable they are, try without the home button installed i guess.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Will try without it i noticed it didnt allow connectors to sit well
さんによる
コメントを追加
回答を追加する
Em4N さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 46
