Box fan makes zingzing sound
My Robeson box fan stopped working, meaning I could hear the motor hum but the blades did not rotate. I removed the blade assembly, cleaned out the dust and oiled the motor. I tested the fan without attaching the blades. The motor seemed to work. After I put the blades back on again, I hear a zing-zing sound. How can I fix this?
2 件のコメント
Hi @anupm12
If you hear the motor hum and it does not spin well, I suggest you to check on the fan capacitor first. It should not crack / bloat or leak.
Augustine さんによる
Augustine, after the cleaning and oiling the motor (with blades removed) does spin properly with no strange noises. When the blades are installed, the motor still spins but I hear a constant zing-zing sound. The capacitor is not cracked, bloated nor leaking.
Anup さんによる
