メインコンテンツにスキップ
Repair guides and support for your LG TV.
1336回答 すべてを表示
Sound but no image. Have replaced inverter board but no joy
LG42LF580V
Sound but no image. Did some research and most forums said it was the inverter board. Order one arrived this morning. Fitted board and same issue. Is there a solution or just get a new TV.?
Update (09/14/2020)
managed to upload a photo
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Twofast2trac any advice on this.
さんによる
コメントを追加
2件の回答
最も参考になった回答
@jteixeira your voltages look good. If your TV is on and you are at a channel that has sound, shine a flashlight at an angel against the screen. See if you can make out shapes silhouettes etc. LG has issues with bad backlight arrays that can cause problems like this. Also, the T-Con board can cause this once it has failed. Check for power on the fuse of that board. Let us know what voltage you get there. Also measure the voltage output from the power board to the backlight LEDs and let us know what you get on those.
You do not have to do the voltage checks since that is already done and those are correct.
If you do not have backlights and since you already changed the inverter the failure at this point would most likely be the backlight array (strips)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hey @jteixeira I would test power at all the boards to see if something is not getting power. If you look at the wires plugged into the boards next to them will be a diagram letting you know what wire has what power?
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
@fasttrackpro thank you for you're reply. I have measured all pins with the TV in the off position and recorded 0 volts on all terminals. I have ordered a new multimeter to retest and to be sure as my current multimeter is old from when i was on the tools. Will update with progress. Is it possible that the readings are true and what does this mean?
さんによる
Test of the TV needs to be ON to get accurate voltage reading?
さんによる
Please see my finding below with the power on this time
さんによる
Twofast2trac Cannon upload the table i created can someone help
Top pin measurements with power on
OV 11.8V 11.8V 0V 24V 0V 3.4V 3.4V 3.4V
Bottom pin
0V 0V 11.8V 0V 24V 1V 3.4V 1V 2.9V
さんによる
On the board next to the pins is a print of the voltage layout. When you test the voltage of the pin layout it should match the print next to the pins.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Jose Teixeira さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 346
