メインコンテンツにスキップ
The Chevrolet Suburban is a full-size, extended-length sport utility vehicle from Chevrolet. It is the longest continuous use automobile nameplate in production, starting in 1935 for the 1935 U.S. model year, and has traditionally been one of General Motors' most profitable vehicles.
46回答 すべてを表示
I have no fuse box in engine compartment 1992 surburban 5.7
I have a fuse box under my dash but the one in engine compartment is not there
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi,
According to the 1993 owner manual (see pages 6-70 & 6-71 also 6-44)there is only the one fuse block, located in the instrument panel on the driver's side.
I realize that you said for a 1992 model but the ‘93 model is the same generation (8th Gen. 1992-1999) so it should be similar
このアンサーは役に立ちましたか?
スコア 2
コメント:
Thank you for answering I was just troubleshooting I don't know why my truck will run like a dream then I'll park it come back and blah it doesn't have a muffler or cat so already loud but it seems to get much louder and performance is s garbage that's how I know how my day is going to be when I start it then out of nowhere my trans dipstick falls out and I'm leaking all my fluid .
さんによる
Hi,
Don't know your vehicle but this link may help to find out what's going on.
If not search online for similar info specific to your particular make and model. Your vehicle is pre-OBDII specs but maybe has OBD. Also sounds as though the engine is shaking too much if the dipstick is falling out - engine mounts or maybe faulty dipstick not sitting tight enough?
Just some ideas
さんによる
コメントを追加
Post photos of engine compartment area, maybe someone can give you an idea of what is going on with your vehicle.
How to post photos
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jason Powers さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22
