メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
Can't find hard drive to install osx
So I purchased a new hard drive because the last one was broken (couldn't get past the white screen with the apple logo) I got the seagate momentus 7200 750 gb 7200 rpm Sata 3 gb 16 mb cache 2.5 inches
I put it in using the repair manuals, and then I booted from my recovery disk, followed the directions but when I got to the step that ask where I want to install osx nothing appears as an option.
I went into disk recovery and the new hard drive is listed as a disk but I do not have the option to verify or repair disk.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
It sounds like you need to format the drive to Mac OS X Extended (Journaled).
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
FYI, I had the same issue (couldn't get past the white login screen, with or without the apple icon, and/or a flashing question mark in folder icon, or a circle with a slash through it; either couldn't find it with Disk Utility, or was unable to repair it, erase it or reformat it). I replaced the Hard Drive, and the new one also failed in an identical way. The good news: We're not alone, and there IS an inexpensive fix for this. Dozens and dozens of others have experienced almost identical behavior. — check out the user stories at the bottom of iFixit's MBP 13" Mid-2009/2010 Hard Drive Cable page, as well as this iFixit forum — in addition to this forum on Apple Discussions, as well as this one. The consensus is that it's NOT the hard drive, but turns out to be the Hard Drive Cable (Apple Part #922-9062), for these units, which seems to have a reputation for failing. IMHO I would suggest that DIY'rs do the most important test first: Remove the drive and see if it functions — either in another unit or as an external drive, with a SATA to USB interface or similar. If it does, then erasing the hard drive and/or reformatting it will not only prove ineffective, but unnecessary. Just replace the hard drive cable (in my case it was this one) and you should be all set.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cableの画像
製品
$34.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I've had two of these in this week with bad hard drive cables. Used ones didn't work only new cables worked.
さんによる
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,536
