メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
iMac 8.1 Screen is oversaturated also on external monitor
I got my hands on an old Imac 8.1.
The screen in standard mode is however oversaturated. I get the same result when I connect een external monitor. I was able to get it a little bit better readable screen with calibration, attached 5 pictures.
2 with the oversaturated screen
2 with the same screens now corrected a bit.
1 from my Imac 14.2 with the same backgrounds to show the difference.
Are there options to tune the graphics card or should I look for a replacement of the graphics card?
The OS is Snow Leopard
Thanks and regards,
Jacob
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First, go into System Preferences, then Displays, then click Color. You should have a lot of options listed. Click on the top one that says Color LCD. You should see the colors change. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you for your answer. I already did that as you can see in the picture 1 & 2. The top option (and other standars) give the over saturated view. As stated I created a calibrated one, which gives a slightly better display but still over saturated view, see picture 3 & 4.
さんによる
@sjakio it might be the graphics card is defective or glitchy so you might want to look into gpu replacements.
さんによる
コメントを追加
回答を追加する
jacobkamminga さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 86
