It won't hold a charge, and screens split
It won’t hold a charge, screens split I put it in repair shop while back. It works but
- The back of the laptop and screen is being held together by tape
- Only works while plug in
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @simonwevet ,
Create a Win 10 battery report to check the status of the battery .
If it indicates that the battery needs replacing, here’s a video that shows how to do this for your laptop.
There should be a model number printed on the battery. Search online for (insert model number) battery to find suppliers.
With regards to the loose parts etc, try searching online for Asus F201E parts or faulty Asus F201E (to use as a donor parts laptop) or check on the inside of the base cover or lid cover to see if there is a part number on it and search online using the part number to try and find replacement parts. Just a thought.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
