iMac only white screen with chime
This iMac 17” 2006 when powered on has chime but only white screen, any solutions?
Generally a white screen issue is related to a failed hard drive.
Insert your original system installation DVD and boot holding down the “C” key. If you do not have that disk you need to have a system compatible external USB source to boot from. Another alternative is using another comparable MAC in Target Mode.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 69
1件のコメント
Could you try the suggestions from this: https://blog.macsales.com/40844-how-to-r...?
Jonas A. さんによる
