I need help to replace spring tentioner s on the back of my HP 4620 pr
I need help to fix spring tentioner s and replace them on my HP 4620 printer
Hi,
Not sure which springs you’re referring to, but here’s a teardown video of the printer.
At 2:58 minutes into the video the two printhead tension springs are seen being removed by using a tool with a hook
At 7:36 minutes, one carriage unit spring clip is being removed. There may be one on the other end of the carriage.
At 11.57 minutes the feed roller spring is shown.
Hopefully this will help you to replace the springs.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 49
