MacBook Air A1466 Not switching on. No magsafe light while trying to c
What part is this?
My Macbook Air 1466 won't switch ON. I tried SMC, PRAM reset nothing works , After opening the MacBook I noticed this part fused. What part is this? Could it be responsible for No charging light and macbook not switching ON?
5 件のコメント
I'd love to tell you Gareth if I could see it ;-{
Go back into 'Edit' of your question using the 'Options' pull down. Then go back into the 'Media Manager' and double click on the image to place it into your answer where the insert text I-beam is.
Dan さんによる
Thanks for the Quick reply Dan, please find attached the image
Gareth Almeida さんによる
Gareth - I don't see any damaged components? I do see some staining on the logic board. Can you make a note in the pic on what component you are concerned with.
Dan さんによる
Hi , please check edit image, and what component is it? It directly placed next to the fan (2).
I cannot seem to diagnose what's wrong with my Mac. It used to abruptly shut off and then finally one day it won't come ON. If I connect the Magsafe no green light. But if I connect another different magsafe green light appears .
[image|2176972]
When I opened the laptop the only observable repair could have been for the IC. Attached zoom in image ( zoom in more and check ) Does the attached IC have anything to do between the charger & SMC ( symptoms: not booting up, blank screen, no charger light while battery disconnected)
