メインコンテンツにスキップ
2017年に発売されたAppleの第3世代スマートウォッチです。オプションで通信機能が付いています。
197回答 すべてを表示
Replaced Apple Watch LCD Screen Won't Turn On
I’m performing a screen replacement for the Apple Watch Series 3. The glass was shattered so I removed the glass and adhesive from the LCD screen and reconnected the LCD screen (it worked). After gluing the LCD screen to the digitizer and reconnecting the battery, the screen no longer works. I think the ribbon cables connecting the screen to the watch may be scratched (see attached images), or I may have applied too much adhesive. I also tried charging the battery and reconnecting all the cables - the screen still doesn’t work. Any thoughts on if the ribbon cable connectors look damaged or any other possible causes for the screen not turning on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
The photo of the ribbon cable isn’t great. It isn’t advised to change out just the glass on a display like this - should replace as one unit or risk damaging the display.
さんによる
コメントを追加
1 件の回答
Hello,
did you solved this thing somehow? I have exactly the same problem here…
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hello @spilmer! Unfortunately not. I think the ribbon cable assembly may need to be replaced and soldered to the board
さんによる
ribbon cable assembly at my case is OK. Maybe connector? I will try different display assembly... But i was super careful and this is not my first digitizer replace. Ribbon replace looks difficult :(
さんによる
コメントを追加
回答を追加する
Eliza Petersen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 435
