メインコンテンツにスキップ
Repair guides and support information for televisions manufactured by RCA.
181回答 すべてを表示
TV RCA rtr3261-b-ca won't turn on
Hello,
I’ve unplugged my TV for 3 weeks while traveling. On my return I’ve plugged it but it didn’t turn on . I've tried practically everything (pressing the power button for several seconds before plugging in etc ...) but nothing works.
Each time I’ve unplugged it, the power LED (which since this failure is always off) blinks once and goes out, and then nothing ...
Any help would be welcome. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@bashibouzouk … when it comes to dead sets, it is usually a power supply issue. To determine this correctly, it will require a multimeter and the ability to use it. Let us know if you have this and we can see what can be done for you.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@bashibouzouk ... so the red light is indicating that you have some sort of life to the set. on the powersupply board (the board that the ac plug from the wall attatches) youll see another plug leading to the mainboard. at the connector on the power supply side, you should see a legend that lists the pins and voltages that should be present. check with the multimeter and see if they match up. post your findings.
さんによる
@jostewcrew … Hi,
Yes I have a multimeter and I'm not so bad on using this kind of item.
If this can also help to solve the problem, the LED in the optical is always on when I plug the TV.
Thanks
さんによる
コメントを追加
回答を追加する
Bassirou Idrissou さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 195
