メインコンテンツにスキップ
2018年4月に発売されたHuawei の最新モデルスマートフォンです。モデル番号はCLT-L29。
56回答 すべてを表示
Broken pin on motherboard
Hi, New to fixing phones, only my 4th. I thought I carefully stripped my phone to replace the camera module, but I had a small pin drop off when I removed the main board. See pic below.
2 options I've had say you can either glue it at the edge to remake contact, and another saying they are not crucial to the phone operating, so leave it off.
Welcome some advice on what's best.
Thanks for any help.
Update (08/19/2020)
Thanks, I'll try that first and test.
I've tried to find schematics online,but not much joy.
No I think he meant glue. I've taken some better pics, as you can see on the part itself, the entire base of it is covered with a red paste/glue. No metal part is exposed where it was bonded to the board. No solder etc. And its sprung between the board and the screen.
And a closer pic of the board.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Justin Ray … without a schematic to know how those pins are functioning on the attached board, either advise is sound enough. If it was a pin that was not connected/functional or even a ground pin that isnt required for operation, you could leave it off. Since this is the easier of the two, i would try this first.
As far as gluing, not sure if it was actual glue being recommended or just a loose euphemism for making a solder joint to reattach the pin to the board it was adhered to. glue is not conductive and probably would just snap off again once pressure to reattach the connector was applied. would need to try and join these with a jumper wire or just a solder joint. Either way, youre looking at extremely tedious work.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Justin Ray さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 18
今までの合計 390
