メインコンテンツにスキップ
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 もしくは3.1 GHz Core i7 プロセッサ
50回答 すべてを表示
How do I upgrade my mid 2014 21.5 iMac?
Hello, I have a mid 2014 iMac 21.5 inch and was wondering how much I can upgrade? I only have the 1.4 GHz Dual-Core Intel Core i5 cpu. I want to upgrade everything to make it last as long as possible. can I put a 4k screen in?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
2件の回答
  • This systems RAM is soldered! So you are stuck with the 8 GB it offers
  • If you have a HDD model you won’t have the PCIe blade SSD connector and its support logic so that rules out any performance improvements by adding a faster SSD drive
  • The CPU is also soldered down so you can’t upgrade it
  • This system can’t support an internal 4k display either!
Basically, it is the least upgradable system Apple made!
So the only thing you can improve is swapping out your SATA III (6.0 Gb/s) HDD to a SSD. Here’s the guide to do that iMac Intel 21.5インチ EMC 2805ハードドライブの交換. If you have a PCIe blade SSD only system you could add in a HDD or a second SSD.
If you happen to have gotten a Fusion Drives system then you could replace the impish 128 GB blade SSD to a more sizable blade SSD (500 GB to even a 1 TB) as well as breaking the Fusion set so you end up with a true dual drive setup which will get you even better performance! iMac Intel 21.5インチ EMC 2805ブレードSSDの交換
Frankly, I think finding a used Mid 2017 21.5” would be a better and cheaper direction iMac18,2 - 21.5” 4K iMac Core i5 3.0/3.4 GHz or a i7 3.6 GHz as you are also looking for a 4K system.
iMac Intel 21.5" EMC 2805 ハードドライブの画像
ガイド
難易度:
中レベル
40 minutes - 1 hour
iMac Intel 21.5" EMC 2805 ブレードSSDの画像
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey Dan,
Thanks for this post! I also got a mid2014 imac (i5 CPU) recently and i was wondering if I could swap out the internal components with another imac that was damaged?
Thanks in advance.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Best to create your own question listing out what you are thinking of re-using in the other system. Make sure you tell us the exact models involved
さんによる
コメントを追加
回答を追加する
Nick Crill さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 41
過去 30 日: 219
今までの合計 6,865
