メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
781回答 すべてを表示
Ps3 not working after sending it to repair?
I opened my ps3 for a routine cleaning, which I do every 2 to 3 years. But this time, I accidentally ripped off the Fan connector on the motherboard. I replaced the thermal paste anyways, and reassembled it back. I turned it on to backup my files and savefiles, but I would only have a 3 minute windows, after which, the console would display a warning message, that it was overheating and therefore was going to shutdown as a preventive measure, which again, is normal considering that the fan was not connected. I monitored the Cpu and You temperature during the process, by pressing Start + Select everytime, it was rising gradually.
Now here's what happened, I sent it for repair, but when I had it back, it wasn't working like before : the fan was connected, but it was messing around. It would max out right away after I boot it, then slow down, then max out again, then slow down and then then turn off, I hear three beeps and there's red blinking. Then when I boot it again, no display, unless I let it sit for a couple minutes.
I wanted to see if it was overheating, but I can't even get to the Xmb sometimes as it would turn off. And I didn't want to open it. I called them, they said it's a Gpu overheating issues, and that there's nothing they can do. How? It never had any overheating issue or whatsoever! But they're trying to pin it on me, saying that I opened it because it was overheating but it was not ; it was a routine cleaning.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sadly there's nothing you can do about this. They probably f up while removing the board and won't admit it. Dishonest shops are everywhere. You could open your ps3 and look around the fan connector. If it's badly burnt bring it back and show them
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
We'll, maybe there's some interference with the data wire, which can explain the fan random speed? Or maybe there's an issue with the heat transistor, that makes the ps3 think that there's a GPU overheating! But even if, why don't I get a warning message like before? Why would it turn off right away?
If I get it back, I'll open it myself. Maybe they haven't reassembled it correctly, or maybe they forgot to apply thermal paste or whatever. But before, I'm considering my legal options.
さんによる
コメントを追加
回答を追加する
Sid Ahmed Mansoura さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36
