メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2614回答 すべてを表示
Won't turn on, red led light blinking occasionally
Currently have a Samsung UN55KU6300, but can’t seem to power it on. Trying to determine what seems to be the issue, but don’t know if its the power supply, main board, or the panel itself. I tried looking at at this (Blinking red light, doesnt turn on) reference to see if I could diagnose, but unfortunately the backlights don’t turn on even when I unplug the power supply from the mainboard. The red led light blinks occasionally but thats it. I attempted to use the remote with it and all it does is make the led light blink really fast similar to what holding down the power button does.
I think it could be the power supply but unfortunately I don’t have a voltage meter to really check it at the moment. I have checked the capacitors but non seem swollen or damaged in anyway.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @technoob231 ,
The LED backlights not turning on when the mainboard is disconnected is not a good sign for the power board, even with the Standby light turning on and the mainboard responding of a fashion but not turning the TV.
Although it could also be that there are two problems, the power board and the LED backlights.
You really need to have a DMM to find out what's going on, otherwise it is just guesswork as to whether it is only the power board or both.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yeah I'm guessing at this point, I ended up buying a power supply and will see if thats the issue.
さんによる
コメントを追加
回答を追加する
TMc798 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 213
