メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
872回答 すべてを表示
What is the size of every screw in the iPhone 8?
Doing a housing swap and stripped 2 screws (managed to get them) that i need to replace. I have a spare set of iphone 8 plus screws, i just need to figure out what size they are.
i do not have calipers or anything to figure out size with, just my eyes.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It’s hard to know exactly how long the screws are without anything to measure them with.
What I would do is to take the stripped screw and compare it to the other screws, start by removing the ones that are obvious, then removing by length etc. and then you should end up with a screw of the right size.
Hope this helped and good luck! :D
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yeah had an old iCloud locked + water damaged SE, just eyeballed various screws on that until I found some that worked. Funnily enough, one of the original iPhone 8 screws would not go back in, as if it was too short! But I found some from the SE that fitted really well.
さんによる
コメントを追加
回答を追加する
Caitlyn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 306
