メインコンテンツにスキップ
ディスク・スペースが足りないですか? バックアップソリューションが必要ですか? 外付けドライブは、オフィスや外出先で追加のストレージを提供します。 このページで修理する方法を学べます。
334回答 すべてを表示
Replace HDD for HDD Box Buffalo MiniStation 2,5" USB 2.0?
Please do me a favor to guide me how to replace HDD on HDD Box External Buffalo MiniStation (2,5" - USB 2.0). I 'd like to replace the HDD inside that box. This is the link of product, it's quite hard to open (no screws +_+):
http://www.buffalo-technology.com/produc...
Pls help me ASAP. ^^
Thank you so much in advance
I love your site ^^
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
Please, anyone? +_+
さんによる
I need helpppppppp +_+
さんによる
This question was migrated from http://meta.ifixit.com/Answers.
さんによる
I still need your help! +_+
After few weeks, I'm still waiting for a solution! +_+
さんによる
コメントを追加
5件の回答
ベストアンサー
I can find no information on dis-assembly of this unit. Looking at the photo of the unit it appears there is a seam going around it. You might try using a Spudger to go around that seam to see if that gives you access to the drive for replacement. Good luck.
Metal Spudger Set
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thanks for your answer,
I think so, but actually I'm afraid my outside box will be damaged.
Should I take some photos close up to all of my device's sides and show to you to get an advice?
Have a nice day! ^^
さんによる
You could call the maker and ask for service. Ask them how to open the device. As I said I could find no information on procedures for replacing the drive--I think they may want you to pay them to do it. There is always risk in trying a procedure like opening a case--you have to decide if its worth the risk to you.
さんによる
コメントを追加
It has a two year warranty.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I made a guide for this, hope it helps.
Disassembling Buffalo MiniStation External Hard Drive (Thunderbolt & USB 3)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks guys, Actually, I bought this device in Korea and there is no official reseller or global warranty in Vietnam for it! +_+ So, I will leave this topic open and welcome all the ideas coming before I break it up! ^^
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
just put an ATM card inside the edge, then lift it up slowly, starting from the long edge!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
quangtrungdesigner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 5,496
