メインコンテンツにスキップ
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
73回答 すべてを表示
Radiator Fans Stuck On High
I have a 2014 F150 4x4 with a 5.0 v8 and it’s just now turned over the 160k mile mark. About three months ago the fans seemed really loud but I’ve not given it any extra thought until now. These babies are working on my nerves! I’ve tried coolant flush and refill and I’ve tried the AC pressure switch. Neither fixed the issue so I’m assuming since the fans only respond to engine temp, trans temp, and AC pressure and both tranny and engine temp is good, I should have my AC system flushed and gassed up with new fluids right? If I’m wrong then I’d like some advice please and thank you!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I assume the fans are electric? If that's the case I would check the fan relay. DON'T DO ANYTHING WITH THE AC FREON R134A. You don't need to touch that system. The ac system is a sealed system and doesn't need service. The only thing that should be checked on the ac system is to make sure the condenser is clear and clean and has good airflow and check the ac compressor belt. The cooling fans have at least 2 speeds. It could be a stuck relay.i would get a electric schematic and trace the circuit and find the issue. Also does it have a manual fan? If so it may have a bad fan clutch and a bad fan clutch can have two issues. First it won't spin and cause it to overheat. Second the fan clutch and freeze and it will sound like a airplane under your hood.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I had the same issue. Started after the water pump was changed. The tech put in an after market coolant thermostat. Eventually I took it to a Ford dealer, they went through their overheating diagnostics and narrowed it done to the thermostat. Put in an OEM thermostat and the problem was solved. I recommend going to Ford and let them do the diagnostics since i could be one of many issues. Hope you get it solved. I agree, very annoying.
さんによる
コメントを追加
回答を追加する
Calhoun Construction Inc. さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 43
過去 30 日: 194
今までの合計 11,333
