メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
84の回答 すべてを表示
Can I replace the graphics card on my ASUS Vivo AiO V230IC?
Need to know how and if it is possible to replace my graphics card without replacing my whole motherboard.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
今あるものを使い続けましょう
オールインワインキットで安く修理して、節約しましょう。
iPhone 修理キットを見る
今あるものを使い続けましょう
iPhone 修理キットを見る
1 件の回答
最も参考になった回答
Hi @ladytiar ,
I don’t think that the GPU (either one) can be easily replaced.
Here is a composite image taken from a charge port repair video for the AiO. I realize that the video is not about your question but it is useful as it shows both sides of the motherboard.
As there seems to be two GPU (see specifications) for the AiO and one is integrated with the CPU (Intel), there appears to be no other plug in GPU (Nvidia) unless it is also under the same heat sink as the CPU. It may be hard mounted on the motherboard.
There is a largish IC visible under the heatsink pipe just back from the CPU but it is unusual that it doesn’t appear to have good thermal contact with the pipe so I don’t think that this is the GPU. In any case it is hard mounted on the motherboard and would not be easily replaced.
You may have to open the AiO to verify all this.
(click on image to enlarge for better viewing)
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tia さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 82
