I changed my front facing camera and speaker but can only take calls
I changed my front facing camera after damaging the cable whilst changing the battery. I can only take phone calls now on loudspeaker. I’ve changed the speaker but still the same
Check the ffc connector for damage and reseat. Where did you get your parts from?
このアンサーは役に立ちましたか?
OPTIONS
Off eBay. It seems that it’s seated ok would that cause the problem with the speaker not working but only the loudspeaker
このアンサーは役に立ちましたか?
Oh Man! You messed up with your front earpiece flex cable. The flex cable should connect to the board which is responsible to get power to earpiece.
このアンサーは役に立ちましたか?
Sorted, it wasn’t quite lined up
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 49
