Toshiba 50L1450U Won't Power on, Power Board seems ok. No light.
I just picked up this Toshiba 50L1450U to repair. It does not power on, there isn’t even a stand by light. When I check the Power Board I see no issues, the voltages match the markings and the voltages follow through to the main board connector. Is this indicative of a bad main board? I’m not even sure what to check on the main board to diagnose.
LED strips tested okay as well.
Other potentially not relevant tid bits :
-The power cord was a polarized cord/connector and somebody shaved down the square side to make it fit like a non-polarized connector.
-the boards are mounted to the plastic backing panel rather than the metallic TV casing. Huge PITA during removal because the boards have to be removed and then somehow re-affixed to the back of the tv for proper grounding which isn’t entirely possible due to the mounting orientation.
Thanks for the help.
Update (07/08/2020)
These are the circuit boards, apologies for the quality. Basically the power board powers the LEDS directly and the mainboard. From the main board there is a harness to the standby light and the t-con. It’s actually quite minimal.
I measured everything I knew how to measure - 5v, 12v, ground. I don’t know how to measure “BLON” or “DIM”
Update (07/09/2020)
@jostewcrew I removed the shield but this doesn't look like the traditional t-con setup I see in other TV's. No ribbon cables. It looks like the cable is going directly into the LCD boards, I see no fuse. Attaching a photo momentarily.
Out of curiosity I tested the Standby/IR LED with my LED tester. At first I got it to light up no issues but then as I continued testing I could NOT get it to light up again. Only a very dim flicker.
Update (07/08/2020)
Ok I’ve tried removed some more panels and it looks like the tcon is integrated with the buffer boards. I didn’t see a fuse but will continue to investigate.
<---This website does not play nice with picture uploads. Preview shows image, no image posts. Try to post as question update - website is not responsive. Try to post picture from phone, photo shows as text. Super glitchy.
Update (07/17/2020)
Power board model #
Update (07/22/2020)
@jostewcrew Okay I received the power board from ebay and it was curiously missing the main fuse. So I swapped in the fuse from my other board and immediately upon plugging in the power cord the fuse blew. I am thinking this replacement power board may have a short which might explain the missing fuse in the first place. What do you guys think?
I’m going to buy some more T4A fuses and try again.
この質問は役に立ちましたか?
8 件のコメント
@chillin014 , in my experience, when the led's check out along with the power supply, it is usually the signal from the main board, feeding back to the power supply thats the cause. if youd like, post some images of the boards interconnections and some close ups of the psu and the mb. also, please list the voltages going from the psu to the mb at the main connector. list the pin, pin label and the reading. post back here with findings for further assistance if needed.
jostewcrew さんによる
Struggling to upload pics
Christopher Hill さんによる
@chillin014 heres a guide that may help:
iFixitでの質問に画像を追加する方法
jostewcrew さんによる
@chillin014 ok... with the power supply. .. please list the pin, pin label and voltage reading with the set off, and once again with the set turned on. this will be for the connector leading to the mainboard from the psu. take the readings on the psu side.
(i.e. pin 1- 12v2 - 11.9v)
however you want to format it is your choice, just indicate off or on on the reading.
jostewcrew さんによる
@jostewcrew understood.
Here are the readings with the TV plugged in. Pressing the power button renders no difference in the readings, it's identical/unresponsive.
Pin 1 (12v2) : 12.55
Pin 2 (12v2) : 12.55
Pin 3 (12v2) : 12.55
Pin 4 (GND) : continuity with ground (not exactly 0, but very close)
Pin 5 (GND) : continuity with ground (not exactly 0, but very close)
Pin 6 (12v2) : 12.55
Pin 7 (GND) : continuity with ground (not exactly 0, but very close)
Pin 8 (N.C.) : no pin/ no reading
Pin 9 (GND) : continuity with ground (not exactly 0, but very close)
Pin 10 (5v1) : 5.13
Pin 11 ( ACD) : 3.54
Pin 12 (PWON) : 3.31
Pin 13 (BLON) : 0
Pin 14 (5v1) : 5.13
Pin 15 (DIM) : 0
3件以上のコメントを表示
