Powers on, lazer moves and adjusts, disk does not spin.
Can the game disk speed be adjusted
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I believe that you are looking at the adjustment for the laser voltage and unless you get a Disk Read Error, they will not work for you. I would check on the power supply to the drive, all the cable connections and the spindle motor itself and see if that is where your error originates. I have some service manual that you can download from here as well as an very informative repair guide right here Hope this helps and good luck to you.
このアンサーは役に立ちましたか?
I'd love to see the manuals, but you need to grant me permission! Would you please? I signed up for an account. Thank you in advance.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,202
2 件のコメント
Can adjustment be made by the two small screws on underside of lazer unit?
William Both さんによる
William give us some more information about what is going on with your PS2. Just wondering exactly what you are trying to achieve...;-)
oldturkey03 さんによる
