メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Anyone leave blue plastic film when screen repair?
Anyone leave blue plastic film when you screen repair?
I was thinking it's little more protection when it drops hard oled is easily crack so…
Or do i need to take off blue film? Then why? Affected color change? Or touch problem or anything affect? Plz let us know thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
It's there to protect the screen finish while installing. It's not made to protect the screen against scratches or cracks/chips. The installer can peel it off for the customer and they can see it's a new screen and no fingerprints when you return the phone. It's a much better idea to buy a screen protector. You can get them for as little as a few dollars.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
He's talking about the blue protective film on the inside of the screen. There is a silver foil behind this. Not the plastic on the outside of the touch screen. That's obvious... And yes, you do remove the blue plastic screen protector over the silver film on the inside of the screen. It will come off very easily.
さんによる
コメントを追加
I wouldn't leave it on, personally. There's no telling what its reaction to heat will be; if the motherboard and/or battery gets warm you never know if it will soften or melt. In addition, since it's not intended for long-term use inside the phone, who know what will happen as it ages; will it turn brittle and flake off all over the inside, or turn to goo and drip all over everything?
Chances are that in the long run it wouldn't hurt anything, but I seriously doubt the tiny extra layer inside is going to be of any consequence in protecting the OLED from damage; after all, most of that damage is going to be coming from outside the phone and the film layer is all the way inside.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kyuho Lee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 202
今までの合計 2,532
