メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Signal drop and keeps losing service "No Service"
I'm facing this signal problem similar to other users. It turns to "searching..." for reception and becomes "No Service" quite often under normal usage. It does re-gain full bar signal when the 3G mode is switched on, and then subsequently repeat the routine. If the 3G mode is switched off, when signal drops to "Searching..." and "No Service" status, the signal will not come back again at all, which means I have to switch the 3G back on in order to get the reception! I have asked other users on apple.com and I first thought there must something to do with the firmware version. It appears no improvement at all even after I updated the firmware version to 4.3.5 (since 4.3.4 was speculated having the key contribute to the signal problems). I'm confused whether it is firmware related problem or hardware faulty? HELP, PLS!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
if you have any warranty left I'd contact apple.
さんによる
hello
i had the same problem. my phone is the 6 plus and i just need to push on the upper corner while it restart to have the reception back. I heard this is because the plus is slightly bending.
try this . it works for me even though i need to do this once in a while
さんによる
コメントを追加
9件の回答
最も参考になった回答
FW was definitely not the issue. Have you ever taken the phone apart? Regardless I'm thinking that your lower antenna connector has come loose or is not fully seated. I would suggest completing STEPS 1-11 of the Logic Board Install.
iPhone 4 のロジックボードの交換
You can skip steps 6-10 and step 11 will show you the connector I'm talking about.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
tnQ so much... very very helpfull and fixed my problem.....
さんによる
コメントを追加
you can replace it with a new blue iphone coil that will fix the problem
you can buy a new blue coil here for the repair
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I fixed my problem by following this guide here http://www.unlockboot.com/2015/10/fix-si...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I checked everything, but after changing the backplate to a transparent one, i have very low signal or nothing. I put back the original and still no improvements.
Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
http://www.myibroke.com/blue-inductor-mo... is a swervice that we offer to fix this problem. its an easy fix for us
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the simplest solution here http://applenewsro.blogspot.ro/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I honestly can't find a way to fix my Unlocked iphone 4 (gsm) tmobile
From dropping signal I can't ever find a fix been looking for DAYS PLEASE HELP
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try taking the SIM card out and putting it back in. Had a similar issue on an iPhone 5 and that fixed it right away.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Let me help you. If you you some data plan from your carrier which assigns different n/w capability for different data type (2G/GPRS, 3G, LTE). So, once your 3G data pack is over, the network goes to 2G mode which the iPhone is not able to connect to. So Head to Settings>Mobile Data>Voice & Data>Change according to your situation
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kefu Pan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60,484
