メインコンテンツにスキップ
The HP Notebook is a portable device powered by an Intel i7 core processor, with a Windows 10 operating system. The HP Notebook model number can be found on the bottom of your device. Model Number: 17-x173dx
1回答 すべてを表示
Laptop showing black visible screen after slipper hit the top of LCD
While I was working out, I took a break and I was juggling my slippers. One of the slippers got out of my hand and hit the top of LCD cover(where the monitor is). Ever since that my laptop showed a black visible screen however my laptop still work normally although I can't see anything. What is the problem? How can I fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Some wiring in the screen has been moved, not powering up the display, or it has been broken completely.
‘Broken’ does not necessarily mean its visible from the outside. In any case, you should open it up to detect if it’s either, and if it’s the later, you may be better off buying a new laptop altogether. This is because of spare part availability, screens being no exception. If you don’t feel comfortable operating on it and (if need be) changing the screen yourself, take it to a technician.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Taje Cytall さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 126
