メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for your Samsung TV.
Why won't my tv auto program?
Why won’t my Samsung tv auto program?
Update (07/07/2020)
Model # UN40H5003
Auto scan for channels
Antenna connection.
Note: Tv less than 3 yrs old when stopped working properly. I expect a tv to last longer. I know you will make this right. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi,
What is the model number of the TV?
By "auto program" do you mean auto scan for available TV channels?
If so are the channels from an antenna connections or a cable connection?
さんによる
Still not working. 1 channel. Can’t believe a Samsung tv does not last even 3 years. I have done everything ypu have asked of me and still nothing. You need to make this right or direct me to a person that will help.
Thank you
Joy
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Have you checked that the TV is setup to receive TV signals from an antenna or a cable service i.e. Air or cable?
Here’s how to do this in your TV. Scroll down to Memorizing Channels
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Hi @ joy palmieri
Is the TV getting the signals from an antenna or a cable "box" you didn't say?
さんによる
its placed on antenna under settings
さんによる
why does it keep stop programming and immediately shut off
さんによる
the tv will only auto scan for channels up to 4 to 6 % then shut off so it only has 3 tv stations
さんによる
why did this conversation just stop samsung ?
the lose of channels now 2nd august 2024 is happening across kent ... this morning auto tune even disappeared from view or use ? .. yes i have a samsung tv
i read that the bbc suggest unplugging the aerial and using auto tune (knowing the transmitter name) ... is this going to fix the channels just disappearing suddenly?
we are in the olympics window and the bbc channels in particular are disappearing
さんによる
コメントを追加
回答を追加する
joy palmieri さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 2,949
