メインコンテンツにスキップ
大きめのアップルMacBook Airラップトップはデュアルマイクと802.11ac Wi-Fi接続を特徴としています。
465回答 すべてを表示
Some keys not working on my keyboard
Hi
I ve got the keys 7, u, j, m not working on my MacBook Air 13 keyboard. I have tried to change the keyboard but I still have the same problem. I have changed the trackpad flex cable but still the same. I did reset SMC, PRAM…with no luck, I also did check in accessibility that I don t have enabled mousse keys. I don t know what s wrong, could it be caused by a swollen battery ? How can I check it and be sure it s the cause without buying a new battery ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I have tried without the battery and I still have the issue. It s working fine with a usb keyboard. Could it be an issue with Trackpad as the keyboard connect to the logic board via the trackpad ? or Logic board ?
さんによる
コメントを追加
1 件の回答
This is usually caused by a small liquid spill shorting out a section of your keyboard.
Here’s how to replace the keyboard (your other alternative is to replace the upper case).
https://www.youtube.com/watch?v=Yt8xZIDt...
Here’s the part:
https://www.newegg.com/p/0GA-02XE-00017?...
UPPER CASE
MacBook Air 13インチ Mid 2013の上部ケースの交換
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Yes some liquid spilled on the Macbook. I have replaced the keyboard with a new one already but still have the same issue. Track pad flex cable has been changed too, the only thing I have not changed yet is the trackpad so I wonder if it s not that.
さんによる
The problem is still with the same group of keys (after keyboard change)?
さんによる
@mayer Yes the issue is still with the same keys after the keyboard change.
さんによる
コメントを追加
回答を追加する
Olivier さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 110
