What screw tip do I need to get battery out?
The tri screw won’t budge the battery screw? It seems too small? I’m using the bit from your kit Y000
You should review this guide MacBook Pro 13" Unibody Mid 2010 バッテリー交換 it will list out the needed tools
In this case you need a Y0 driver Tri-point Y0 Screwdriver which is why you are having troubles.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 42
