メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2018年3月に発売されたiPadの第六世代モデルです。32もしくは128GBのストーレッジオプション付きのWi-Fi あるいはLTEモデルが選べます。 64ビットA10チップと9.7インチRetinaディスプレイを搭載しています。
141回答 すべてを表示
Why did the touch/digitizer function randomly stop working?
Customer brought in an iPad 6 (A1893)
The digitizer no longer functions at any capacity.
It is a company iPad, so it is in pristine condition.
Factory resetting device hasn’t worked.
I removed the screen- unsurprisingly, an OEM lens.
No signs of liquid exposure internally- again, pristine.
No visible connector obstructions.
I have tried TWO replacement digitizers to no success.
Board issue?
maybe its the touch disease curse of Apple 6th generation products?? /s
Any further insight would be greatly appreciated.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Steve B,
Hold down the circular Home button and the On/Off (Sleep/Wake) button at the same time for around 10 seconds. This will restart the device and should restore the screen to full working order.
Hope this helps,
Sincerely, Onlaf
このアンサーは役に立ちましたか?
スコア 0
コメント:
thanks for the response Onlaf. attempting the soft reset, you speak of, was something we’ve tried from the beginning. we just received our third screen assembly(from varying vendors, at that) still no success in regards to the digitizer function yet the LCD has functioned fine with each replacement we’ve tried. the flex connectors visibly appear fine. even the solder connection on the board side looks fine. i’m assuming an underlying board issue but just throwing it out to the community to ensure there isn’t another approach i could take in resolving this .
thanks again,
Steve
さんによる
コメントを追加
回答を追加する
Steve B さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 27
