Earbuds will not insert into earphone jack.
My earbuds will not insert into the jack. It seems as though something has dislodged in the jack or something broke loose.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Look at the tip of the earbud input jack and see if it has broken off.
このアンサーは役に立ちましたか?
I had to clean audio jack from cotton debris once. It went there from the bottom of my pocket. I couldn't insert earphones plug fully anymore. You can clean it with toothpick, if that's the case.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,529
