メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
596回答 すべてを表示
Is it possible to install TWO 2TB SSD 2.5" Drives?
Hello, 15” MacBook Pro 2012 Unibody. 16GB RAM. 2.6Ghz
Can I put a 2TB SSD in the Hard Drive Bay and an additional 2TB SSD in the optical bay using the adapter?
I’m asking because there seems to be a question as to the capacity of drives in the optical bay… something about 750GB?
I’d REALLY like to just put TWO 2TB drives in as they’re really cheap now ($199) and it’d be a great upgrade to have. Any answers will be appreciated.
Update (06/22/2020)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
This isnt related to the question but what site are the 2tb ssd for $199 on because i cant find them any where
さんによる
@doddleboddle - I think this is the drive Crucial 2TB BX500 SATA III 2.5" Internal SSD
You do need to be careful as some drives don't have any onboard RAM to hold the table ({https://www.tomshardware.com/reviews/dra...|DRAMless SSD]) so they are cheaper and slower!
さんによる
Yep the Crucial on Amazon
さんによる
コメントを追加
4件の回答
ベストアンサー
There are different issues at play here …
Lets start at the top level first, what is the limit of OS-X/macOS - The largest you can go in a single volume is just short of 2 Exabyte within HFS+ and even larger with APFS (I don’t recommend using APFS on SATA based systems). So YES! You could do it from this perspective. But there’s more to the puzzle!
Space: The physical limit of the bay will constrain what will physically fit. This is where you are likely hitting as the given SSD size needs to not exceed what the special adapter can hold: (WxHxD) 100 X 69.85 X 6.8 (mm).
Power: The larger the drive the more power it needs, but to be clear two SSD’s require more power than one larger SSD of equal storage! So getting a single 4 TB drive will require less power than two 2 TB drives. This will effect your battery run time.
SATA I/O: Do both SATA Ports offer SATA III (6.0 Gb/s)? This series it does! If you have something other than a 2012 model you can have issues!
The 2011 models and older have a logic board issue in the optical bay SATA logic. Here’s a good writeup from OWC on it OWC Data Doubler you need to stick with a fixed SATA II drive if you have one of these systems.
SATA Performance: Using two I/O channels can be more effective than one I/O channel. But, not in all cases! If you isolate the OS (boot drive) and the apps to one drive and use a second drive for your data then you can have better performance when the data set is very large. Like large video & music scores, other uses like image processing and DB’s can also gain performance but not as much. Having two volumes (either on one drive or two) can be effective from a backup strategy if you are good in isolating your apps from your data. You can also invoke tighter security on the data.
SSD Performance: This is tricky! As a single larger drive has a faster read/write compared with the same series which is smaller in storage space (a 1TB drive is faster than a 512 GB) . But! the technology of the flash cell can have big performance and life span ramifications. Here’s more on this Wikipedia - SSD
Your work flow: This gets into your work process and what the applications and data sets would find the most efficient.
Price! While not obvious the price per GB is less with bigger drives! So a single 4 TB drive is cheaper than two 2 TB drives.
So! Where does that leave us?
My own 27” iMac uses two SSD’s a 512 GB and a 2 TB. The 512 is just running my OS and apps, whereas my 2 TB is my data drive. I did this to gain the performance of the dual SATA III (6.0 Gb/s) channels this system offers, yet not waste space on the primary drive which won’t be used. So what I would do is something similar to this in your system. figure out what your work flow needs for a boot drive, apps, libraries, cache, virtual RAM and any scratch space allocations your apps use figure on that being what you need plus a bit more space for growth. The data drive is setup to support my data I will be working with and any data I will likely want (i.e. music). Today I’ve migrated my work to a 2013 Mac Pro with a 2 TB blade SSD and a 8 TB external Thunderbolt RAID drive!
So don’t get so hooked on the size and focus on your needs.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
For $600, you can now get a 4TB SSD:
https://www.amazon.com/Samsung-Inch-Inte...
or for $450 you can get a 4TB SanDisk here:
https://www.newegg.com/sandisk-4tb-ultra...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Don't forget the data doubler is around $30 bucks ;-}
So its close to a wash with the SanDisk drives.
I did forget the 4 TB drives are still sold at a premium! Was thinking 512 GB and 1 TB.
さんによる
コメントを追加
I'm told the max capacity an optical bay on a 2012 MacBook Pro Unibody machine can hold is 750GB.... THAT is my question. Can I put a larger capacity drive in there? Like a 2TB or more? No one seems to be able to give me a clear answer. :/
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@rmcluesman - I did a few 2TB drives! If you want a black and white answer then:
* Yes, if the drive physically fits (some of the drives are physically too large)
* No, if it doesn't!
But thats not the best answer! Which is why I gave you the full run down!
さんによる
Just a simple answer, yes you can use 2 tb hdd , but you can’t use 2 2tb hdds
さんによる
Incorrect I went ahead and installed them anyway, to see, and it works perfectly no problems
さんによる
In laptops things can get tricky! Using two drives (any) does increase the power draw so if you are on battery your run time is less.
SSD's tend to use less power than HDD's unless it's writing data.
Presently, MacOS doesn't support RAID-0 or RAID-1 on boot drives. Apple's direction has become clear with the M Series systems only external data drives will be supported with any RAID setups.
さんによる
コメントを追加
@rmcluesman I have the same question. I already have a 500GB SSD in my 2021 Unibody and was looking to replace the mechanical drive (750GB) that sits in the optical bay. I bought a 1TB Samsung SSD but when I connected it to the optiical drive connector, Disk Util would not let me partition it or erase it. Therefore I suspect your information aboiut a 750GB limit in the optical bay is probably correct. Where did you get that information? Ultimately the new 1TB drive will be the main drvie with the older 500GB as a secondary drive (once I've cloned it) but I'm away from home at the moment and don't have the tools to do the swap and clone.
このアンサーは役に立ちましたか?
スコア 0
13 件のコメント:
@neilbaldwin - OS-X and macOS are not the issue! Both can support Exabyte drive spaces which you clearly are not even close in size! So if its not the OS then it much be physical? Nope! The SATA interface can support larger volumes 20 TB is possible! OK then what is the issue?? Its the drives volume/format structure! You need to use disk utility to fully wipe the drive as FAT32/exFAT is limited! Make sure you use GUID and a journaled file system (HFS+ or APFS)
FYI - I've setup a few systems with 2TB drives without any issues.
さんによる
@danj Thanks for the info Dan. So are you saying I need to first use Disk Utility to erase the drive and format as FAT32 *before* I can partition it for OS X (AFPS)?
さんによる
@neilbaldwin - NO only use GUID with either HFS+ or APFS.
"Its the drives volume/format structure! You need to use disk utility to fully wipe the drive as FAT32/exFAT is limited! Make sure you use GUID and a journaled file system (HFS+ or APFS)
What’s the Difference Between FAT32, exFAT, and NTFS?
macOS Mojave is the highest I would go with as Catalina kills 32bit support. In any case Catalina is as highest as you can go in this series.
If you need a windows partition create it afterwards and use GUID with it MS - Frequently asked questions about the GUID Partitioning Table disk architecture
さんによる
@danj
"NO only use GUID with either HFS+ or APFS"
That's where it was failing Dan, Disk Utility fails when I try to erase the drive (tried HFS and AFPS). This is with the SSD connected to the optical bay.
さんによる
@neilbaldwin - Give me the details of the drive you are trying to install - Make, Model & Size. Which MacBook Pro are you also installing in a 2012 or older system?
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Robert Cluesman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 598
