Microphone is broken after upgrading ssd
Any idea where i can get that part?
the ribbon is so fragile, looks like it broke
thanks
Update
After changing the microphone for a new one it is still the same problem, no idea what happened, i was being very careful inserting the flex cable on the board.. when removing the original one i pulled it instead of removing the tiny latch because i did not know
Any idea?
Thanks
9 件のコメント
@dubcode
It sounds like it is the ribbon that is broken.
Can you please add a picture of how the ribbon looks? iFixitでの質問に画像を追加する方法
Erik Eriksson さんによる
Like i said i bought a new one, so its almost impossible 2 broke?
Also tried installing a microphone from the 4k imac 207 and still no sound?
is it possible i broke the logic board connector when pulling the microphone the first time?
Thanks
Guillaume さんによる
@dubcode
Ohh, I forgot that you mentioned that.
Look if you can find a small part off the old ribbon in the connector and add a picture of the connector on the board by following the guide I sent in the comment above.
Erik Eriksson さんによる
@eke0909
Uploaded thanks
Guillaume さんによる
@dubcode
Can you also add a picture of the connector on the board side without the ribbon inserted?
Erik Eriksson さんによる
4件以上のコメントを表示
