メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
368の回答 すべてを表示
Replace Logic board with Late 2009 logic board?
I bought this from a govt auction. They pulled the hard drive out, but in that process they broke the display adapter on the logic board. Can I replace this board with a board from Late 2009?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Please post a few pics of the damage iFixitでの質問に画像を追加する方法 so we can see what you need.
さんによる
Hi Dan, I just uploaded a couple of pictures.
さんによる
Yup it is possible
if you find my answer useful please click accept as a solution.
さんによる
@imacman123 - So how you you fix this?
Saying its possible is not an answer!
さんによる
I meant it is possible to use a 2009 replacement logic board on an iMac 2009 sorry for misunderstanding.
さんによる
コメントを追加
3件の回答
最も参考になった回答
I’d see if I could disconnect the connector body which was pulled off with the cable from display cable, then connect it to the logic board and secure it with Kapton tape then connect the cable back to the display.
この回答は役に立ちましたか?
スコア 3
コメント:
@mayer - Yes, threading the plastic shell back is a possible solution!
さんによる
So, the logic board connection would be the new "permanent" connection?
さんによる
prabs That's the idea. Straighten those pins up some before doing it first.
さんによる
Thanks. I will give it a shot or try what Dan suggested.
さんによる
コメントを追加
Here’s a vid showing the steps to re-tin the pads after desoldering the pins from them iMac 21,5" & 27" LVDS Display connector repair and here is the connector LCD Display LVDS Cable Connector (30-pin)
You may want to find someone with the needed tools and skills to put a new connector on. This would be the best solution if you can’t get the pins re-inserted into the shell.
この回答は役に立ちましたか?
スコア 2
コメント:
Thanks. I will ask if my buddy can give it a shot or try what mayer suggested.
さんによる
コメントを追加
The best solution would be to solder a new socket on the board. Try to fit the broken one is risky cause you could short pins and damage the display and (or) the logic board. There's 50v passing thru the socket to the display cable.
この回答は役に立ちましたか?
スコア 1
コメント:
Long time, no see
さんによる
コメントを追加
回答を追加する
prabs77 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 72
