My MacBook turned off and even if I charge it it won't turn on.
I know that you can tap alt, cmd and a letter from the keyboard but I don’t know witch one. Can anyone help please?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I believe you are referring to an SMC reset. “SMC“ stands for “System Management Controller" and it controls how power flows through the components of the machine. To reset this, follow the instructions in the following image:
Since you have a 2017 MacBook Air, the next thing I would do is check to see if this machine is covered under AppleCare. You can check this by entering the serial number (located on the bottom plate of the machine) here:
https://checkcoverage.apple.com
If you are not covered under AppleCare and an SMC reset does not resolve the issue, there are a few other things you can try.
If you haven’t tried using a separate charger, try connecting a separate, known-good charger and attempting to power on.
If this doesn’t work, you may need to troubleshoot the internal battery. Open the bottom plate and disconnect the battery, then with battery disconnected and machine on its side, attempt to connect a charger and power on (be careful not to touch any internal components when the machine is powered on). If the machine powers on with the battery disconnected the battery may be failing and may need to be replaced.
Hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 31
