メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Replaced Battery, Still not Turning On?
I have an iphone 7, it finally gave up last week, wouldn’t turn on anymore. I tried DFU and the phone died in the middle of the process.
Installed a new battery today, after about an hour’s charge, I plugged it into iTunes, where the DFU process worked as expected. I downloaded a whole software update but now the phone won’t turn on at all, won’t respond to hard reset or DFU. What’s going on?
Do I need to wait for the battery to fully charge maybe?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This could be a software issue. If that’s the case, you should probably ask Apple for help…
However, if you are 100% sure that the battery isn’t the problem, there might be some issue with the logicboard. That’s possible to replace, yes but hard. And you would probably lose touch ID features as each individual home button is paired to the logicboard to the phone. And with the fact that this isn’t a physical button and just a sensor, you won’t even get the ability to click your home button unless you go through Apple which will re-pair a new one for around 379$…
These issues are always hard to fix, as I usually tell most people to restore the whole phone, but it seems like that isn’t an option here… I don’t like to say it, but I’m afraid that Apple is the only way here if no genius here might have a great solution.
But if a wipe and a restore is possible, I highly recommend you to hook it up to iTunes and restore the phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Truglia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 44
