Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,247
1件のコメント
Of course the engine turns over, and there's a spark from the coil wire?
originalmachead さんによる
